Originally Posted by gizzardgulpe
I used the instructions in the Chilton manual that resulted in such poor timing that I couldn't accelerate into traffic safely. I cannot seem to log in to the state library website to get back to the manual to double-check what I learned, so that'll have to wait for a day or two, but I seem to remember it saying to set the timing to ten degrees at ~600 RPM, and that was just obscene. The car barely ran.
This sounds about right to me, in the static position without advance.
Important steps in the process.
Short the terminals of the check engine connector to check the timing-1983-84 Cressida
Allow the engine to run at the specified idle speed with the gearshift in Neutral with manual transmission and Drive (D) with automatic transmission.
Procedure
| Repair Guides | Firing Orders | Ignition Timing | AutoZone.com
