I just got back from a quick trip having just adjusted the timing. I've lost a considerable amount of power. Not as bad as before, when I set it to 10 degrees at 600 RPM; now it's at 10 degrees at 800 RPM. It's very sluggish and the engine vibrates a bit more.
Something just doesn't seem right.
Also, I just found out how to test the EGR, so that's going on the to-do list.
