Hi Duncan, I'll email you the new code hex file (and c code if you want it).
I love manual contactor control!
Yes, you need to provide the controller with 9-18v.
The pins on the pickit are the same as on the board. The dot next to pin 1 on the board is the same as the pin with the triangle pointing at it on the pickit 3.
To program it, you don't need anything connected except power to the control board and the pickit 3 connected.
