Originally Posted by nemo
Does this happen?
Yes. The engine slows by about 100 RPM when I short the connector, then jumps up when I remove the wire. The timing changes by a degree or so as well.
@ redneck:
Yes, it has the selector and it works. It basically sets the RPM/Load ratio to shift at lower RPM in economy mode, so with gentle acceleration, it won't get over 2000 RPM before it hits overdrive.
It bothers me that I'm barely getting the EPA estimate after all the work I've put into this car.
@NateHale88:
I can't afford much, but PM me a price and we'll talk. ^_^
