Old 11-03-2014, 06:23 PM   #17 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by beatr911 View Post
If it significantly eliminates the need for cold enrichment, will there be an injector into the exhaust to light off the cat?
Blasphemy on a small car with this system why would you need a cat?
erm in any event if you were to use this to lean out idle especially during cold start the fuel would make much more heat than normal due to being around stoich (or leaner still ?), the heat of exhaust can light off the cat just as well as too much or too little fuel.
Too much fuel no matter how you slice it makes more pollution, we shouldn't concern ourselves with the type of pollution just that less fuel is always less pollution by volume (aka Co2 and volatiles)
Cheers
Ryan
