Maybe, if possible to do it cheaply, we could use a solar panel to power an air compressor and use that to pump air into a scuba tank, then use that air to push you along for that extra boost when you EOC and don't want to turn your engine back on. This would all have to be without using the alternator and would have to be placed properly as to not increase aerodynamic drag.
