Old 11-03-2014, 09:32 PM   #17 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by awcook View Post
Maybe, if possible to do it cheaply, we could use a solar panel to power an air compressor and use that to pump air into a scuba tank, then use that air to push you along for that extra boost when you EOC and don't want to turn your engine back on.
There are too many conversion losses. Solar energy -> electrical -> mechanical -> compressed fluid.
It would be much more efficient for the solar panel to drive an electric motor that is attached to your drive-train.
As you point out, the solar panels would have to be applied in a way that doesn't increase drag. The problem is that cars move relative to the direction of the sun. It's a poor use of solar panels when you could just mount them in an optimal location, such as the roof of a house, and then charge a vehicle with the energy produced from the rooftop.
