Old 11-05-2014, 01:00 PM   #18 (permalink)
freebeard
It's looking good so far.
I like conveyor belting as a material, but I've only ever used it in conveyors. Is the edge finished or cut? What widths were available to you?
The bump in the center may stiffen the lower edge more than a smoother curve would. When you re-curve the outer ends would be a be good time to add triangular filler pieces.
I think you're on the right track with the camper shell. Are you still going to form it from cardboard? How would that work?
