Old 11-05-2014, 07:59 PM   #6 (permalink)
BlowNdoh
Here is the framework we built. It is aluminum and we did not drill any holes into the metal. We only drilled into the plastic fender well for the side pieces. For the side pieces we used the running board bolts. Some of the materials we used are 1/4" threaded rod, nylon nuts, washers and body bolts.
ID:	16291   Click image for larger version
Name:	side panel 3.jpg
ID:	16292   Click image for larger version
Name:	Side panel 4.jpg
ID:	16293   Click image for larger version
Name:	Cat area 5.jpg
ID:	16294   Click image for larger version
Name:	cat area cutout 7.jpg
2003 Ford Excursion 6.0l 2wd Mods: Dynomax BTM Muffler on stock exhaust, belly pan, grill block, 3.55, MPG 18 city 23.7 hwy
2002 Ford Explorer Sport Trac Mods: Lincoln Mk8 electric fan with Dakota Digital controller 17 city 23 hwy
2010 VW Jetta TDI stock
1996 Chevrolet Impala SS
