The GM 6.5 is almost a bolt in but gives a more crowded engine compartment. The GM 6.5 and the Cummins 3.9 are about the same weight - 700 pounds.
The Cummins is taller and may require some hood mods, but I'd just do the same hood reslope that Phil (Aerohead) did on his T-100. The Cummins would require the motor mounts to be relocated.
Either engine will require body sound deadening material.
Not only does the Caprice have a better Cd, but also a slightly smaller frontal area. The pickup has a roomier driver's position and a more upright seating position.
Much to consider.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
