looks complicated, those manifolds are not cheap to produce either. Why would you need so many holes in your exhaust, EGT sensor and a Lambdasensor before and after the cat, unless they are going to run some fancy, complicated new injection system, but why would they then use a single overhead cam.
I do think they are using a 'Heron' type cylinderhead, by the looks of the pistons. So probably quite high compression.
By the looks of it, the are also planning on direct fuel injection.
