Old 11-07-2014, 02:44 AM   #6 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
During testing I have also lost one plug in wheelcover assembly. It came off from a cover where the holes werent drilled so straigth compared to the zipties incoming direction. I will shoot a hubcap assebly video today to show how to do it.
I have tested my hubcap assebly to 160 km/h 100MPH speeds with 4 plugs used in the assembly.
If the holes arent in rigth place and specially it the hubcaps dont center themself to the wheel. You need to be extra careful in the assembly:
- Tighthen the plugs litlle by little. To get the hubcap fixed to center of the wheel
- Make sure the locking teeth is facing against the zipties body. This way you know that there is some tension in the ziptie. If it is not touching the tail your connection is not secured properly
- One plug can handle 10 kg of pulling force so they dont break in the assebly phase specially in hubcap assembly.
Some pictures to clear that description:
"Loose"
"enough tension"
Same in video format:
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
MetroMPG (11-07-2014)
