Old 11-07-2014, 10:40 AM   #5 (permalink)
redneck
Do you have any fabricating skills and have access to tools...???
If so, it would be fairly easy to build something off your existing trailer. The top and sides that you have now are whats heavy. I would replace that with a lighter weight materials as in either thin plywood or even better, thin aluminum.
For a aerodynamic body, use 1x4 wood for the tear drop shape of the frame,as it is fairly easy to bend and shape then skin it over.
Have you tried using the search box located at the top left of the page ?
There are several threads pertaining to trailers that may help you.
