Originally Posted by a8ksh4
Well, I've thought a bunch about it and am just going to keep picking away at this project. I put the shell back on the truck last week and camped in it over the weekend. Should be using for several days over this coming long weekend, too.
I need to go snap some photos, but I built the back door for it and put down some carpet inside to make it more comfortable. I've come to really enjoy the bits of construction I do I using lightweight wood, either with wood glue or fiberglass. The backdoor on this thing is super lightweight and only took a few minutes to assemble (will take a bit longer to finish and paint), sort of same as for the awning door.
hi,I just found this tread,and was wondering how strong is this kind of fiberglass over foam structure?
How much weight per square foot do,you think it can support?
I was thinking about doing a truck camper shell similar way mostly to save weight..
Thnx
