Old 11-09-2014, 06:00 PM   #36 (permalink)
undeRGRound
undeRGRound's Avatar
Originally Posted by RedDevil View Post
If it would put positive ions into the fuel then where do the negative ions go?
The unit is grounded, that could answer your question...
As for a fuel heater, I have seen many MPG enthusiasts place a brass fuel fitting on the exhaust manifold to heat the fuel. Might create a vapor bubble on a hot shutdown, but the EFI pump could easily overcome this in a matter of seconds. Just not sure of the safety of this with standard metal lines.
I have a theory that copper pellets (wire cuttings) could act as a catalyst if the fuel was hot enough. All the crap additives in gasoline would eventually coat the pellets, and reduce the effect.
