It has a small insert below the front bumper, & not sure what an e-fan is!
25 would be great, but I would like a solid every day 25 as well. I don't believe that is asking too much, and all without getting into the engine itself. If I have to build a long block, I would certainly "throw the kitchen sink" at it. D. Vizard has a build procedure for prepping the cylinder walls, using scotch brite pads to gain almost 10 HP through reduced friction. he freshly built, fully assembled long block can be cranked over with 2 fingers on a breaker bar, whereas a normally assembled short block (no heads) takes in excess of 100 ft-lbs to turn!
