Old 11-10-2014, 10:13 AM   #23 (permalink)
cosmick
Experienced UAW Mechanic
Only if he had the 5-speed.
I'm having issues with the matching center caps on the front. And problems with the parking bake cables. Gotta trash the Ford under-spring plates, they damaged the shocks. The S-10 versions should work when I get the lowering blocks reinstalled, but it may need new u-bolts. New shocks will wait until I can afford air shocks. New RR parking brake cable will be the RR for a '73-'75 Ford, NAPA part number UP93599. $ 24, but should solve that problem once lowered. LR TBD, but possibly UP93896 for $ 27. Seems like something is dragging, or not rolling freely, and it's leaking gear lube past the new diff cover gasket. Gotta figure out attaching the sway bar to the frame.
But it drives very well.
No regrets.
