Old 11-10-2014, 11:55 AM   #107 (permalink)
xavi
So, as with other load-sensitive engine efficiency modes (like lean burn or cylinder deactivation), modifying the car to reduce rolling & aero drag expands the eco-cam "window of operation": LRR tires, tire pressure and aero mods for example.
never tought of that like that, but yes, any mod that makes low load more steady you can maintain eco cam longer and get better FE...
but it is much more easy to keep it in eco cam by going higher in rpm (more hp/torq available)
so this mode is "made for" cruising at high speeds, only after 3.500 rpms it turns off...
under 2k rpm any hill will make you go off eco cam, cause need more load, that will disengage it...
The Following User Says Thank You to xavi For This Useful Post:
ChazInMT (11-18-2014)
