Old 11-10-2014, 12:05 PM   #109 (permalink)
xavi
It might be easier to keep it on the eco cam at lower RPM by using a "throttle smoothing" modification as was done in the 1st generation Insight:
http://ecomodder.com/forum/showthrea...tor-25641.html
have watched a "3 drive throttle controller" just yesterday:
Throttle Controller "3-drive Series" 3-drive · COMPACT | PIVOT
you can see some vids with civics on youtube...
it connects to the drive by wire sensor in the gas pedal, and has the sport and eco feature that gives fast or slow response from the gas pedal...
that "compact" in the link is more eco, cause top eco mode, never goes above 80% throttle even with the pedal full apllied..
I only lost my hope on it, first because it seems to expensive, second because you also have to connect it to obd port, wich I have already in use with SG...
The Following User Says Thank You to xavi For This Useful Post:
MetroMPG (11-10-2014)
