Remove the shroud from the motor. That's the part that is rubbing on the axle as it rotates.
Move inside the car. Interface module is inside now.
Run the motor up in neutral (100A is too low, even for neutral!)
Duplicate the test with 300a maximum on the motor. It runs fine
Put the car in 3rd gear, then run up the car. I didn't check the speedometer
Mazda MX6 Day 125 Video 036 Nov 1 2014 - YouTube
