Old 11-10-2014, 10:03 PM   #1 (permalink)
kafer65
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
mirror delete with integeated blinkers
My to do list includes side mirror deletes. They are next to useless and I use the rearview spot mirror to deal with the huge c-pillar blind spot i have now anyway. My primary concern is that they are mounted to the door skins not near the a-pillars. Second problem is integrated blinkers. If I remove one will I have to put a resistor in to spoof the electrical circuit to blink at the right rate or will it act like a bulb is out and blink too fast? I found a good diy for getting after the bolts that hold it on. finding time block to make a plate that i could bolt back in is also holding me back. Any insights from the gurus are welcome.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
