Old 11-11-2014, 12:00 AM   #1301 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
I got the flywheel attached, cyrusCosmo! It works great.
That's WONDERFUL news!
I tested the battery current limiting, and it seems to work. You can set it to take no more than 'x' amps from the batteries, and separately, no more than 'y' amps into the batteries. That is a separate control from setting the max "motor amps" (line to line amps). I'm going to just send out the controllers to the 2 beta testers,
wwwooOOOOHHHHHHOOOOoooo!!
and worry about polishing the details from a distance. I think it's at a place where the fundamentals are good. So, adding the brake regen feature will have to be added on later.
Works for me!
I don't have a way to test that at all at the moment. I'll just send it with the wig-wag throttle. You can set the regen territory to be any amount you want, so it could just be the small amount that we were talking about that causes the car to feel like it slows down a bit when you take your foot off the throttle.
As long as I know the rules, I'm sure I can work with it
It will be interesting to see how the PI loop tuning goes. For now I'll make a separate C file for that, that will need to be run in debug mode with a locked rotor (emergency brake on?) at a relatively low voltage (48v??).
48V DC on the pack, locked rotor on the motor. Got it. Are you still doing the pulses on the unloaded motor to get the rest of the parameters?
I could do it all as a config mode in the same software as the regular C file, but I'm just trying to keep things simple at the moment.
Simple is GOOD
So, I just need to test the UART and EEProm stuff, and then I'll get the stuff together and ship them out. I hope you guys didn't pay for shipping already. haha. If so, then it will get shipped out in about 2 weeks (payday). haha
I don't remember paying for shipping. You should have my address from paypal. Let me know if you need me to PM it again. And what it'll cost to ship.
Have you shipped to Canada before? I'm told there are many rules, and that they change a lot.
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (11-11-2014)
