With my small compressor, if moisture was a serious concern, just run the compressor until the tank is full, shut it off, let it sit overnight, bleed the water out of the tank and you have moisture free air for your tires.
I used that procedure to paint cars and never had water in the lines, which will ruin an otherwise perfect paint job.
regards
mech
