Originally Posted by MetroMPG
Felicitations on starting your course. Sounds fun. And the commute is not horrible either.
Thanks. The commute is a little bit harder to obtain very good mileage (110+ mpg when hot outside). But it is a bigger challenge so I like it
Can you explain? If it's too cold you can't charge?
Rmay pretty much summed it up, when it is near 0°C or colder, the NiMH batteries stops accumulating the charge really quickly and starts releasing it in heat.
Originally Posted by Daox
Woo, thats a lot of maintenance. Good luck.
Thanks.
