Originally Posted by OG VX
Ah, I see. My bad, I missed that earlier. Considering all that, amazing numbers!
What app are you using to log your fill ups? Looks like you also used MapMyFitness for an elevation mapping, correct? Great idea!
Any pics of the front air dam?
I use Fuelly.com exclusively to track my mileage and you are correct about MapMyFitness being used to show the elevation change for the route. I actually used this tool for route planning because I have three different routes I could have chosen to make my daily 55ish mile commute. This one shown is the preferred based on traffic flow, minimizing stops and elevation changes. One of the other routes actually had an elevation change of over 1400 feet.
My air dam is pretty simple but not nearly as low as yours. I went under the assumption that I only need to be ~1" lower than the lowest hanging component on the undercarriage, besides the control arms, this was my exhaust. This lip is very sturdy and hangs 1" lower than the lowest exhaust component.
I also installed a kill switch into my 2000 civic center console over the weekend
