Old 11-12-2014, 02:29 AM   #240 (permalink)
HyperMileQC
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
I have a SOC reset device that I bought from M. Dabrowski. It is a plug and play OBD-II device. Here is the link : http://99mpg.com/projectcars/socresetdevice/
With this device I can set the SOC gauge to 19 or 6 bars on 20, Set the IMA battery module fan to fast or slow speed and reset both MIL and IMA lights. When I take my car after charging it I set it at 19/20 bars and I usually am at 2 or 3 bars when I arrive from my commute.
I charge at only 338 mA with the fan always on so I don't think there is much battery deterioration. I try to maintain it active and use my car at lest 1 day per weak so it is not self discharging too much. So far my 8 years old battery seems in pretty good shape since I started to grid charge it. It gives full assist for a good amount of time and can take a lot of regen before being "full charge".
When I do my Charge and discharge process every seasons exept winter (brrr..) I check the Amp/hour of the battery and I get 6.5 or 6.6 every time. When my battery will begin to be really finished I will buy a bumblebee battery .
About the cruising speed I cannot tell a constant speed. I do P&G cycles of 52-39-52 mph on the highway. The max is 62 and the min is 37.
My city driving is mostly flat some up and downs from viaducs but nothing big.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
The Following User Says Thank You to HyperMileQC For This Useful Post:
Ecky (11-12-2014)
