Old 11-13-2014, 02:26 AM   #10 (permalink)
redpoint5
90 day: 43.3 mpg (US)
I've run out of fuel in every gas operated thing I've owned.
I once calculated that I could go 500 miles on a tank of gas in the Camry. On my commute from Salem to Portland, the gas light came on. Knowing that I should be able to go 500 miles, I decided to drive all the way back ~50 miles to the Fred Meyer in Salem. The engine died as I turned the corner to the gas station, and the odometer turned over exactly to 500 miles as I coasted to the pump.
Originally Posted by Old Mechanic View Post
Try it in an F350 car hauler after one of your "friends" borrows the truck and brings it back, so low on fuel, you can't make it to a gas station a mile away.
With friends like that, you don't need enemies.
