If you are looking for best FE, just look at MPG numbers and stick to a relatively high number, I wouldn't worry about engine load and RPM, those don't mean that much in Final drive. If your car can keep its speed consistent up a hill while keeping the same FE, then that's actually really good. I'd only be worried if you gained speed up hill, that would mean you are doing something wrong!
