Old 11-14-2014, 09:07 PM   #106 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Mazda MX6 Day 131 No Video Nov 7 2014
Check contactors by connecting to the 12V battery (controller is disconnected)
12V - the primary contactor closes, resistance is 0.1
12V - the secondary contactor closes, resistance is 0.1
So the controller appears to be the problem .. sigh!
Next time I will check the outputs from the controller. The first controller has a failed primary contactor output (I think) so I'll check on that first. Then work through the second contactor output, then the precharge sensing
It's cold outside. I may need to clean up a space in the garage so that I can work inside.
