Originally Posted by Blue Angel
Thanks! Some interesting info there. So my 1000W Zerostart should be plenty for my 138hp engine.
Neat project with the water tank heater element, BTW.
The reason I chose the 1000W heater size instead of the larger 1500W size was the power draw limit of a typical 120V 15A circuit. I don't have the luxury of 240V supply in my garage and I would like to run this heater along with the 200W OEM oil pan heater and maybe even a small adhesive pad heater on the bottom of the transmission. A regular wall plug can only give so much... I'd like to keep total power to 1500W if possible to keep from overloading the breaker.
Blue Angel, did you ever complete this project? I'm thinking about doing something similar with our xB to try and cope with these Vermont winter days.
