The ima system is required for the vehicles lean burn to work. Those equipped with lean burn are easy to get 3 digit mpg with a good or bad battery.
Batteries can be replaced or rehab.
Id try a motorcycle drivetrain, 2 cylinder engine if Id changed the drivetrain.
