Old 11-15-2014, 10:15 PM   #1312 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by P-hack View Post
Interesting re: dual motors. To me the simplest is to just one set of igbts and one controller in slip mode and two motors in parallel. Read both motor speed signals and take the max speed for determining slip (prevents wheelspin runaway and encourages the slower one to speed up). Set 0% throttle to not regen and coast around the corners when you can. The latter fits well with "good" driving, traction pie habits anyway, you *shouldn't* be braking or accelerating much while turning and saving your traction for changing direction.
What do you mean "slip mode"? If A motor like the one in your car unsyncs from its rotating magnetic field, it looses ALL torque. It might work fine for an induction motor, but definitely not for a BPMSM.
Also, there are plenty of "good" drivers who would disagree with you about when to brake or accelerate. You'll find them on most racecourses.
