Nice white vx! More than likely you'll need to replace the transmission input shaft bearing. It's a common failure due to insufficient transmission lubrication. The Trans oil 5w30 should be changed at 15K intervals. The job is big, but doable if you have moderate mechanical skills
In the garage:1993 civic 1978 hobbit 1976 jimmy
