It looks like you've gotten a good start on it. Once you get underbody panelling, wheel spoilers, double side skirts, and wheel boattails installed so that the underside is aerodynamically clean, then you could lose that air dam, which adds to the frontal area and is only beneficial if you have a aerodynamically dirty underside you need to divert the air away from.
