Old 11-18-2014, 02:37 PM   #1332 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by cts_casemod View Post
Ill give it a try mailing Dave and asking if he could supply some of that stuff he shows on the video. I would not be surprised if he already had al algorithm
to use with texas instaspin libraries. That would make your work significantly easier.
Thank you very much!
I am downloading all the lecture info and lab excersises and animations about the Prius motor - there might be an equation with some #'s there. In my case, I'll probably have to change them a bit (it's not exactly the prius motor, it's an MGR with very similar specs)
It's a goldmine of good info - and really icing on the cake that he uses the same motor for a demo!
BTW, for anyone using ANY motor (not just FOC stuff) here is a quick link to the supplimentary info he gives with the lectures. The lectures are very helpful.
TI E2E Community
- E*clipse
The Following User Says Thank You to e*clipse For This Useful Post:
freebeard (11-18-2014)
