What sort of throttle do you have? Is it 0ohm to 5kohm at max throttle? I'm sure it's just a software setting that's the problem. Sorry about that. I'll check the max battery amp setting, but it probably is something to do with the throttle settings. I think there are 3 different throttles for the controllers, but just one C file that I change when one of them needs an update.
