Old 07-19-2008, 01:26 PM   #73 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
If you look at the area of the red smoke, it does not change very much between versions.
Perhaps reducing the vortex size is a goal in comparing shapes with this software?
Also, I wonder if the effect of turbulence on the vehicle aerodynamics diminishes with the distance of the turbulence behind the vehicle? In other words, turbulence close to the vehicle has a greater effect on the wind resistance measured for the vehicle?
Nissan Versa Aeromods
