Originally Posted by Cobb
So you are wiring this and your brother into the homes power panel or are you getting a second line from the power company.
I have a 25 year old home and was advised to get a new panel or a whole new service and meter if I wanted level 2 or 3 charging for an ev.
Also Prolly BS
Unless you live in SoCal and the local building codes are capitalizing on the anticipated influx of EVs, then there is likely nothing you can do but comply. Unless you get a good "rogue electrician" who can hook it up safely and covertly.
