Old 11-19-2014, 03:56 AM   #10 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Originally Posted by serialk11r View Post
Off topic, but I'm surprised you're idling at 0.19gph with that Skyactiv engine. My 1ZZ-FE (designed in 1999) is 0.18-0.19gph idle. I would've hoped that with direct injection, high compression ratio, better VVT, and such that they would've been able to cut idle consumption more than 10% (since the displacement is bigger on the Skyactiv).
At 17 degrees outside temp, I'm guessing the seat warmers and heater was on. Perhaps the headlights were also on. This would call for higher idle consumption.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
aerohead (11-20-2014), kafer65 (11-20-2014)
