Old 11-19-2014, 01:32 PM   #13 (permalink)
taco
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
Can't hurt. Block the brake vents too unless you're crazy hard on 'em.
i dont understand what you mean by brake vents.
the black pieces under the headlights are blocked and so are the pieces under them.
the center has the slit above the black bar and the center section of the mouth open then a little bit of the piece under the bumper is open. then it has a shield the covers all the underneath to the rear tires.
i got to find some more coroplast and i will completely block it off( center part.)
Originally Posted by serialk11r View Post
Off topic, but I'm surprised you're idling at 0.19gph with that Skyactiv engine. My 1ZZ-FE (designed in 1999) is 0.18-0.19gph idle. I would've hoped that with direct injection, high compression ratio, better VVT, and such that they would've been able to cut idle consumption more than 10% (since the displacement is bigger on the Skyactiv).
ill check it when i get to work the eve.
this car is also the pzev if that matters. drops hp from 155 to 154 dont know what else it does.
no heated seats in the i touring, did have fan on 1 out of 4 and the temp set to the middle.
The Following User Says Thank You to taco For This Useful Post:
kafer65 (11-19-2014)
