Michelle in Denver here. I also bought a 92 VX. Found it on eBay, flew to NC and drove it back. It has 267000 miles on it and has gotten as high as 47 mpg 2/3 city highway, 1/3 city. It has also dropped to a mere 39 the past two fill ups.
My mechanic is thinking thermostat or distributor since it also would not re-start at a drive through. Obviously I avoid idling.
The engine is being gently cleaned and I'm changing the oil every 2,000 miles.
It had a recent tune up, has new tires set for current weather conditions.
I've been using regular gas (10% ethanol), from the same Shell station.
Until the past cold snap, the weather was mild with little wind.
Anything you can suggest to be more consistent? What might explain this?
I Also have a 97 HX and have some widely (-5, 6) varying mpgs
