Old 11-19-2014, 03:23 PM   #17 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
As a general rule, if you're going to only block part of the grille, leave the center open. The reason for this is that if you have the sides open as you have now, you are spoiling clean airflow coming from the very front of the car. It is instead best to pull from the stagnation point and let anything outside of that flow around cleanly.
One notable exception is the Civic EG, whose radiator occupies only the passenger side of the grille opening.
The Following User Says Thank You to Sven7 For This Useful Post:
Daox (11-19-2014)
