Old 07-19-2008, 03:46 PM   #8 (permalink)
ALS
2.73's are too high for that set up. The best bet is to go to 3.08's from the 3.27's. The computer and transmission are already set up for the 3.27's.
You go to 2.73's you will take your car way out of it's power band and confuse the transmission of where it should be shifting. Don't you love computerized cars we have today. In most cases, you noticed the word MOST the automobile manufactures drop the optimum gearing by a set to improve the acceleration. It is the happy medium between fuel mileage and drive ability that is built into the cars today. It's like tire pressure.
They recommend 34 psi for the ride although 40 psi would be much better for fuel economy. There is always a compromise.
Around town there will be a minimum improvement in fuel mileage but expect between 1 and 2 mpg better on the highway. The trick is to incorporate multiple improvements to maximise the fuel mileage gains.
