Old 11-19-2014, 06:08 PM   #60 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
power off retries
Success! Changing pwr off retries keeps the ultragauge on.
Compatibility > pwr off retries
If ultragauge at times enters low power mode and briefly turns off the display ... increase the number of retries (5 is default) until the behavior stops. A side effect of increasing the value is that ultragauge will remain on for a longer time after the ignition is switched to off. Changing this setting to a value greater than ~45 is not recommended.
Changing the value from 5 to 33 keeps the ultragauge on for 10 seconds after the toggle (ignition) is switched off. This is plenty of time to switch the toggle back on, and then the ultragauge continues to stay on.
The Following 3 Users Say Thank You to j12piprius For This Useful Post:
California98Civic (11-21-2014), Fat Charlie (11-20-2014), pletby (11-29-2014)
