Originally Posted by UltArc
Does anyone know much about the rear defrost system? My fourth Insight has working rear defrost, but the third does not- I want to wire the whole camera system to it, three monitors and three cameras- turning on when I push the button, off with the button or when the car is turned off.
Searching IC, I found no information on it, and none of the manuals will load for me. Any advice, tips, or links?
The leaky seatbelt problem causes this. There is a blue plug where the seatbelt is behind the pillar where it leaks, and that is for the defrosters and trunk latch. The defroser is the first to corrode enough to stop working, and eventually your trunk hatch won't work either.
