Old 11-19-2014, 09:31 PM   #15 (permalink)
spacemanspif
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Small update. We have had some cold weather here the past couple of days with 30degree days. Using my scangauge I'm seeing that my intake temps do not change as I drive. I make note of the temp when I start the car just to see how cold it is out, and have noticed that it stays there, or, if I'm lucky, it will go up 2 degrees. I'm thinking this is going to hurt my MPG all winter long and am trying to think of a way to warm up the air. The Duratec has the intake at the front of the car and exhaust close to the firewall; this might not be an issue except that all the emissions and PZEV "junk" is occupying the space that I would use to wrap a snorkel around the engine and pull hot air off the exhaust manifold. Many Focus owners have noted warmer intake temps and unconfirmed MPG gains from using a short ram intake with cone filter; I'm thinking about testing the "redneck" short ram but first I need to get a MAF tube off another Focus to hack up.
In other news, I plan on removing the roof rack side rails over Thanksgiving weekend, so hopefully that will cancel out what losses I might be seeing from winter temps...
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
