Old 11-20-2014, 11:21 AM   #24 (permalink)
kafer65
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Nigel, thats some good information! Its got to be tough to calculate the speed of sound in a medium that is shedding heat and becoming more dense as it travels through the tube. On my Beetle header I loose so much heat before it gets to my turbo its hard to get it to build its full boost potential. It takes tens of seconds under acceleration to build the header heat for the turbo to convert to the last 4 lbs of boost. I have Jetcoated headers but I'm going to wrap them and put aluminum around that to keep oil off of the wrap. So many variables to contend with. You have the amount of fuel being consumed adding changing temps in the exhaust flow and the temps already soaked into the header and the speed of the airflow around the header pulling heat out too.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
