See, that's what I originally thought, then I started second-guessing myself. It's easy enough to change the logs again, though.
The worst part is, I actually had this straight at one point, because I used to have a truck with somewhat oversized tires, so I actually sat and figured it out way back then (2001 or so).
Edit:
Correct corrections added to fuel log and my spreadsheet.
This boosts my actual FE up quite a bit!
