Old 11-20-2014, 09:46 PM   #36 (permalink)
Daox
If your header is creating more low end torque, wouldn't it make sense that it also creates more knock? Higher charge density = more knock, right?
Higher charge density at the same ignition timing should always mean better efficiency (assuming everything else is constant). However, if your engine must retard timing for a higher charge density, then you can obviously lower efficiency. It sounds like this is what is happening to you ever_green.
