Edit: looks like it's already been stated. I'll just leave it here anyway.
The stagnation point will be a high enough pressure area to get air through your radiator, especially if you duct it. You don't need a big cantilevering front end to make it work; almost all active members here have some form of grille block, so just check the project threads. You can have a reasonable grille opening and still not cause unreasonable drag. It's a balance.
What car is it?
